Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für die 2020er Neuauflage des MacBook Air. Erschienen im März 2020
94 Fragen Alle anzeigen
Do I need a new screen only or are there other problems?
My daughter dropped her A2179 MacBook Air and her screen now has lines that have gotten progressively worse but it appears the progression as stopped as you see them now in this video:
https://youtube.com/shorts/FiWDU1wiCb4?f...
There are no visible cracks in the screen. Is it likely that the screen is my only problem and a replacement will fix the issue?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi Brent,
Yeah, that's definitely a cracked LCD panel. I would have a high degree of confidence that replacing the screen will fix it.
Keep in mind that the MacBook displays are non-repairable (at least not for us home DIY-ers) - you can't just replace the LCD panel separately from the digitizer, for instance; you have to replace the entire display assembly.
MacBook Air 13" Early 2020 Display Replacement - iFixit Repair Guide
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Brent Fidler wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 47
