Zum Hauptinhalt wechseln
Das Samsung Galaxy A10e ist ein Android-Gerät der unteren Mittelklasse, das Samsung im Februar 2019 veröffentlicht hat. Es ist über die Modellnummern SM-A102(U, U1, W oder DL) identifizierbar.
white screen Have an A10e
Have a A10e with like a white screen with horizontle lines what needs to be done?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi Shawn,
It's hard to say exactly what's going on with your phone without seeing what the screen looks like, but so far from your description it sounds most like you will need to replace the LCD display. We can probably give you a more definitive answer if you can take a picture of what the screen looks like. Here's a guide on how to add pictures to your question.
Adding images to an existing question - iFixit Repair Guide
That being said, I didn't find any written guides to replacing the display on your phone, but there are guides out there for similar phones such as the A10 and A10S.
If you do end up having to replace the screen, generally there are two ways to do it. You can replace just the LCD or you can buy one with the frame preattached to it. There are advantages and drawbacks to both.
LCD without frame
Advantages
  • Less disassembly of the entire phone required
  • Cost is usually slightly lower
Disadvantages
  • More fragile, so easier to break during assembly/disassembly
  • Needs to be sealed securely to the frame
LCD with frame
Advantages
  • LCD is preattached to frame, so less chance of damage in the process of removing and replacing it
  • Better structural integrity with a preattached frame
Disadvantages
  • Significantly more work moving all parts within the frame to the new frame
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Shawn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 311
