Zum Hauptinhalt wechseln
Intel's Skull Canyon generation of the gaming-focused NUC line.
Question identifiying SMD Component - Capacitor?
Hello everyone, I have a question that I posted on Reddit and got a few contradicting answers. I purchased this Intel NUC6i7KYK as "Parts" on eBay because it was power cycling. I originally thought it just needed some cleaning and new Thermal Paste, but that is not the case. I was looking at the bottom of the board, and found what I believe to be a blown capacitor. I attached a stock picture, and circled the component in blue. I know it is impossible to identify the exact specs of this part, but at least knowing what type of part it is will point me in a direction to troubleshoot. Since the board is dead, I really have nothing to lose by trying to fix it and learn from it. According to Reddit, it is either a fuse, capacitor or resistor. One suggestion would be to put a 0ohm resistor in and try it, but I don't want to do that if it is actually a capacitor. Thank you in advance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Looks like a resistor, the caps are a browny colour. I’d try and find a resistor the same dimensions and try it. Remove it from the board first and see if there’s any measurement across it. I’d also check for a bad mosfet.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Perfect, thank you very much for the quick reply!
von
Antwort hinzufügen
Likwid wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 43
Insgesamt: 654
