Charging port replacement issue
So the tablet i have was not on the choose your device section, it is the sasmsung galaxy tab a7 10.4 in i believe the model number is SM-T500. Anyway at one point i dropped it and form then on the tablet would only charge when the cable is pressed in at an angle. I have tried multiple charging cables on this device and others that i have so i know its not the cables. I opened the tablet and bought a new charging port, Im not sure if the 2nd one i bought was doa or what but it does not take a charge either. there are these 2 metal prong type things on the bottom of the charging port i dont know if those need to be touching the case for ground or what the deal is. I have ordered an additional charging port replacement but i was wondering if anyone has had similiar issues and what you found works. As far as i can tell this is the only issue with the tablet.
Left one is replacement, Right is from the tablet
Ist dies eine gute Frage?
@jmitchell94 can you post some pictures of all of this with your QUESTION? That way we can see what you see. Bilder zu einer vorhandenen Frage hinzufügen
von oldturkey03
added images
von jeff
If you can at least post the picture of the charging port you ordered for . Then a proper insight can be given on. If it’s actually the proper charging port or not
von Ubiquicktous Solutions
added images
von jeff
