The GeForce GT 730 was a graphics card by NVIDIA, launched on June 18th, 2014. Built on the 28 nm process, and based on the GK208B graphics processor, in its GK208-302-B1 variant, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_0.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
5 Kommentare:
Nina Titi what fan? The one on your PNY GeForce GT 730 graphics card? What have you checked?
@Nina Titi can you check the fan by just applying voltages to it? Do you have a small power supply that you can use for that? Make sure you apply the proper voltage of course. That way you can rule out the fan as the cause.
von oldturkey03
I am not quite sure on this model but the fan should not spin until it reaches a required temperature.
von Chris Stables
@imicrosoldering But it never rotates even if the temperature rises greatly, and it does not rotate even though it receives electricity
von Nina Titi
@oldturkey03 Yes, it does not rotate. I checked its access to electricity and cables, and it rotates heavily once and stops
von Nina Titi
von oldturkey03
