Zum Hauptinhalt wechseln
The Smart Oven® with Element IQ® is a trustworthy tool for the cook who wants a countertop oven that roasts succulent meat, broils, bake pizza, reheas leftovers and toasts evenly. Convection setting reduces cooking time by up to 30%. Model: BOV800XL
Why does the bottom elements looks much less orange than the top ones?
Just recently toast is only toasting on the top side. The bottom elements are on but much less intense than the upper elements. What could be the cause of this do I need to replace the bottom elements?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
halkamm just to verify, your toaster oven is a Breville BOV800XL?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Check your settings. Rotate the knob a few times to see if the contact was just not set correctly.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
That did change the appearance of the heating elements. The two lower elements look blotchy as compared to the bright solid orange color of the upper ones.
von
Sorry - that did NOT change anything.
von
halkamm The uneven light of the heating element is either caused by it being a bad heating element, or by the Control board PWM which may have failed. These are not your daddy's toaster. This a quartz element heater. Time for you to take it apart and let's take a look at it. Use something like this video to take it apart. Then take plenty of pictures and post those with your QUESTION. That way we can see what you see. Adding images to an existing question - iFixit Repair Guide
Bewertung 0
Antwort hinzufügen
halkamm wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 1,002
