Zum Hauptinhalt wechseln
Die Neuauflage von Apples iPad Air Tablet vom März 2019, das mit dem A12 Bionic Prozessor und dem 10,5" Display antritt.
20 Fragen Alle anzeigen
iPad Not Powering on - Charger weird readings
Hello everyone.
My iPad Air 3 stopped working. I then found out that the display was defective and replaced it. After that, it fully boots up once. I let it charge to about 80% and then turned it off. Now it doesn't work anymore. When I plug it into the charger it shows 5V and rises to 2.2A charging power and then drops to 2V and 0A only to then rise again to 5V 2.2A. This repeats itself endlessly.
No Apple logo or anything like that appears on the display. I've already tried a reset via power + home button.
Board looks clean so far, nothing gets hot when the charger is on.
Any tips ?
Thanks and Greetings
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If the charger drops to 2v then I'd try another charger. Should be constant 5v at least.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
kilkenny91 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 64
