Blank Screen after replacing JoyCon
I replaced my Switch Lite's left JoyCon, but now the screen will not turn on. The fan spins up, and the speakers make noise when I press any buttons. How can I fix this?
Ist dies eine gute Frage?
Check the small ribbons about halfway up on the left of the board are seated properly. Below the card reader if I remember correctly. One is for the back light and if not inserted correctly causes a black screen.
War diese Antwort hilfreich?
Both ribbon cables seem to be seated properly, they are in as far as they can go, the gold contact is facing up, and the fastener is secured.
check the ribbon connecting the daughter board to the motherboard, make sure on the daughter board side the gold contacts on the ribbon are facing up and not down
Both ribbons appear to be secured properly, with gold contacts facing up and inserted as far as they can go. I'm really stumped here
If you still have the original joycon, then you could try to put it back.
This would help rule out potential hardware issues with the new joycon, if you are 100% sure it's not a poor seat on a ribbon connector.
I would also inspect and unseat the screen ribbons and make sure they and the connector slots are clean.
Letzte 24 Stunden: 6
Letzte 7 Tage: 29
Letzte 30 Tage: 107
Insgesamt: 1,790
5 Kommentare
what do you mean by replaced the joycon? the analog stick?
von just some mango
did you mean you replaced the buttons? or did you choose the wrong device/modified the lite?
von timtom77
@sadmango Yes, I meant that I replaced the analog stick, sorry for the misunderstanding.
von Aidan wheeler
@timtomissus I replaced the moving analog stick, as it was broken off.
von Aidan wheeler
Same problem but right side
von EmersTheMoo03
