I switched out the Power Supply and it still wont turn on.
My PS4 Pro wouldn't turn on and whenever I hit the power button the blue light would turn on with the beep and then shut off after a second sometimes and other times it simply wouldnt do anything or just beep with no light, I'm at my wits end and don't know what else could be causing the problem, any suggestions?
Ist dies eine gute Frage?
Bewertung
0
What happens when you try and power it on by sticking a disc in? Looking to rule out the VSW-00X board/socket/ribbon. Problem with PSU/board should present consistently. https://imgur.com/a/0gvFRlp
von Dan Sayers
Ill get to trying that when I can I'm currently occupied at the moment but I'll let you know how that goes thanks for the suggestion.
von Brian Martinez-Estrada
@dushku ive run into another problem the disc drive rollers are stuck, i had taken it apart to 1 check if there where any burn marks amongst other thing and also to retrieve a disc that was stuck when the console died i took off the metal plate and didnt think much of it the tried your suggestion and noticed the disc wouldnt go in so i took it apart and was seeing if i messed anything in the reassembly process and that when i noticed the rollers are stuck ill try to get them unstuck and then get back to you on your suggestion
@dushku I finally unstuck the disc drive but in short your suggestion did not work, any other things I should attempt?
