Why is my ps3 flashing red and beeping 3 times?
My ps3 was working fine until I took it upon myself to take it apart and clean it. I watching a tear down video followed all steps to take it apart. I took main parts out like power supply, disc drive etc. down to the motherboard I didn’t take it apart out of its grey shell because I didn’t need to just wanted to clean dust. Clean the dust and hit some spaces with 99% isopropyl alcohol, the only places I touched with the alcohol was black plastic and the top of the disk drive on accident. Done cleaning put everything back but on screwing in the motherboard I accidentally used one of the power supply screws into one of the wholes( didn’t screw into it 100%) heard a lil crack stoped and realized and did it the proper way put everything back to normal and I was done plugged it in turned it on clicked on a downloaded game and in 3-5 min i heard beeping and flashing red. I tried my best to give the most amount of detail to narrow down my issue/answers. I’m not a technician but my own 2 answers are I shorted the circuit somewhere causing the fan to not start or I cracked my motherboard when using the wrong screw. Plz give me a strong for sure answer
Ist dies eine gute Frage?
3 Kommentare
Forgot to add I used air duster to get most of the dust out maybe 95% air duster and 5% alcohol
von Anthony Badillo
I'm wondering, where did you end up putting the power screw before you realize that something cracked and you were using the wrong screw? If it was in a place somewhere where it could have affected the CPU or something that is required for the operation of the PS3, you may have broke that part.
von Jri-creator
@anthonybadillo take a couple of GOOD pictures of the area where you used the wrong screw. A view of both sides of the board will be needed. It is easily possible that this is a torn trace or otherwise damaged board, but it depends on what area. Post some pictures with yuor QUESTION Bilder zu einer vorhandenen Frage hinzufügen
von oldturkey03
