Zum Hauptinhalt wechseln
Das 13" MacBook Pro, das im Mai 2020 auf den Markt kam, ist mit Quad-Core Intel Core i5 und i7 Prozessoren der 10. Generation sowie mit integrierter Intel Iris Plus Grafik ausgestattet. (Modell A2251/EMC3348 mit vier Thunderbolt 3 Anschlüssen)
Yellow stuff coming out of speaker
I'm looking to repair an A2251 macbook pro but there's yellow stuff coming out of one of the speakers. The MacBook will turn on but won't stay on and nothing comes on the screen (main screen or when connected to a monitor). Would it be worth replacing the speaker or do you think I would need to replace the battery as well. I'm assuming that since the MacBook won't stay on, it would also need a new battery.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
thats liquid damage, try turning it on with the basics connected like screen, battery and keyboard, also check the logic board for signs of damage
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Yeah, I have to agree; that's not something coming out of the speaker, but rather something that got into the speaker from outside the case; i.e., something got spilled on it once upon a time. Use liquid damage mitigation procedures on anything that looks like it may have been affected.
von
The stuff came from outside a spilled drink maybe?
In any case you need a few parts like speakers and there is likely junk stuck under the logic board. This could get expensive if it’s not too late now. Get some cotton swabs and pads to clean as much as you can. Just dampen the cotton so nothing wrings out I would use distilled water or 80% isopropyl alcohol. Don’t use tap water as it’s loaded with minerals and salts which you don’t want.
Review this Teardown des MacBook Pro (13 Zoll, 2019, 2 Thunderbolt Ports) as that should help explain your systems construction.
Bewertung 1
Antwort hinzufügen
Lucas Marins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 356
