Zum Hauptinhalt wechseln
Seit 2006 fertigt Kirchen Aid dieses Rührgerät mit 10 Geschwindigkeitsstufen.
Can I bypass the control board to test the motor?
I bought a used mixer that isn't running and would like to test the motor before I invest in a new control board. Is it possible to temporarily bypass the control board to test the motor? I have already ruled out a short in the power cord.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@eraskin yes it is. Use thios guide KitchenAid Professional 600 Motor austauschen and disconnect the motor controller from the motor. Then apply power directly to the motor. How you accomplish that, will depend on what you have available. I would use test leads with alligator clips, and come of the main power supply from the mixer. Of course, you can also just take a stripped power cable and use that :-) Whatever you got .... It'll buck since it will get a full load so make sure everything is clear in the transmission etc.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Evan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 412
