Zum Hauptinhalt wechseln
Which is bad, battery or charger
My "greenworks pro" 60 volt lithium battery is not taking a charge, but I I don't know if I need a new battery, or a new charger. Do you know any way to determine this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
6 Kommentare
try a new charger first
has the charger been exposed to water or is it frayed/ripped anywhere?
von
Thnx, timtom. I'm trying to figure this out without having to buy one (that I might not need, if mine is good) to try. Those chargers are kind of expensive...
von
No, not apparent physical damage to the charger, and no exposure to water that i know of.
von
@tvz62367 hm
does anything else that uses the same port work with the charger?
von
@TVZ do you have a multimeter or can you borrow one?
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@tvz62367 Do you have a charger number? You could use an ammeter and put it in between your charger and your battery and see how many amps it draws. You can do some basic test with your multimeter. Check something like this It tests the same way for your battery as well. Let us know what you find out.
War diese Antwort hilfreich?
Bewertung 1
I tested the voltage that the charger is putting out. It's much lower than a similar charger (different brand) that I have. I have ordered a new one. Thnx to all for the suggestions!
Bewertung 1
1 Kommentar:
The new charger will break too. I got ripped off by greenworx rubbish. Not worth buying a 3rd charger
von
Antwort hinzufügen
TVZ wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 679
