Zum Hauptinhalt wechseln
Der TI-84 Plus CE ist ein grafikfähiger Taschenrechner, der im Frühjahr 2015 von Texas Instruments herausgebracht wurde. Er verfügt über einen 2,8-Zoll-Farbbildschirm, einen USB-Anschluss, Apps, Speicherplatz und einen 1200-mAh-Akku.
My calculator is not charging or turning on
Hi, I just got my calculator (TI-84 plus CE) in the mail and it wasn’t turning on so I plugged it in using the USB cable provided that says it’s for “data transfer and convenient charging”. I am worried because the screen is flashing with a message that says “calculator will restart when validation is complete” so it doesn’t seem to be charging. It’s still not turning on and I have no idea what to do, please help. (This calculator doesn’t have a light on the side so I am unable to see if it is charging or what the battery percentage looks like)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
well when i hold 2nd and del and the reset button nothing happens i tried it on the charger and off the charger
von Teilen
Same thing is happening to me with a brand new one I bought my son. 😩
von Teilen
so I am a math teacher and had a student come to me with the same issue.
I tried the charging stations in my classroom all day. Brought home last night and cord charged. tried the 2nd del buttin where I can see something happening, but the blinking does not allow for a steady hold including the reset on the back.
Finally based on the above suggestion with the battery it works.
I have my personal calculator that I tried it with an wah-la.
If it's new return it for a replacement. I bet if you call TI they will have you send it to them and they may do it for you.
Good luck.
von Teilen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Leave it charging for a few hours. If it still boot loops then press and hold 2nd and del (they're the top full sized buttons on the keypad) then press the reset button on the back of the calculator with a pencil for at least two seconds. You should see a message that says "send OS now". Do not press clear.
Leave it charging on this screen for another few hours. Afterwards, press and hold the reset button on the back of the calculator for at least two seconds again (but don't hold 2nd and del this time). This might cause the calculator to boot normally.
If you get the same "send OS now" screen then press the clear button (rightmost column on the keypad) and proceed with an OS reinstall: TI-84 Plus CE Wiederherstellungstechniken
If it still boot loops then you likely got a defective unit. I'd return it for a new one.
If returning isn't an option, you can try buying a new battery and replace it. Texas Instruments TI-84 Plus CE Batterieaustausch
TI-84 Plus CE Batterie Bild
Anleitung
Schwierigkeitsgrad:
Leicht
1 - 5 minutes
TI-84 Plus CE Bild
Anleitung
Schwierigkeitsgrad:
Leicht
5 seconds - 10 minutes
War diese Antwort hilfreich?
Bewertung 1
This is an issue with many calculators during a time period. The batteries were not good. I have a large number of HS Mathematics students constantly requesting a new battery. You know it's bad if it is blinking and won't stay on.
I teach and have purchased 5 calculators for myself and my own children. There has never been an issue with those batteries( over 9 years old at this point and hold a charge well over a month) need an actual battery from TI. They cost $5 however, Ithink that TI should replace them.
Bewertung 0
1 Kommentar:
TI will replace the battery for free if the calculator is less than 2 years old! https://epsstore.ti.com/OA_HTML/ibeCZzpH...
von Teilen
Antwort hinzufügen
Danielle Mann wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 32
Letzte 30 Tage: 137
Insgesamt: 20,722
