My phone get in to water
My phone get in to water how can i rid it
Ist dies eine gute Frage?
Hi @abduhussen
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Using rice does not solve the problems caused by corrosion, so don't use it to help dry out the phone. Rice is for dinner, not repair
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a teardown video of the phone that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
War diese Antwort hilfreich?
Turn off your phone and remove the battery if possible.
Dry it as much as possible with a towel, paper towels, a soft cloth, or a vacuum cleaner.
Depending on the type and amount of liquid, you may need to rinse it with still tap water or bury it in a container of rice or silica gel. This may take a few days.
Car Games.https://www.zdnet.com/article/how-to-get...
Check your phone’s water resistance rating and compare it with the depth of the liquid it fell into 1.
It’s important to note that these steps may not always work and there is no guarantee that your phone will be fixed. If you’re still having issues with your phone after trying these steps, you may want to consider taking it to a professional repair shop.
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 194
1 Kommentar
Les caméras ne fonctionnent pas
von Oumar Touré
