How can my tablet be fixed?
My fire HD8 tablet screen is cracked What should I do?
Ist dies eine gute Frage?
First you need to be sure the actual screen is cracked. Does it look as if ink is running down the screen when you turn it on? If not then most likely it's actually the digitizer that's cracked and you simply order a new digitizer and install it. Google will bring up a you tube video and show you the exact procedure for replacing it.
War diese Antwort hilfreich?
@ooleygrider here is the guide on how to replace the display assembly. It's easiest replaced as a complete assembly. Amazon Fire HD 8 Display tauschen
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 17
