How to fix blue lines on screen
Hi. The screen has a few fading blue lines even when it is off. How do I fix this? It shows a little without light but a lot with light.
Ist dies eine gute Frage?
@anhadchugh just going by your description but this sounds very much like a bad display. BlackBerry 7280 LCD Screen and Speaker Replacement Post some pictures of what it shows, with your QUESTION. That way we can see what you see.
Anleitung
Schwierigkeitsgrad:
Mittel
10 minutes
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
War diese Antwort hilfreich?
Where can I find a replacement screen?
@anhadchugh that will be the biggest challenge. YOu can try and see if there are any numbers on the back of the LCD screen. If so, use those numbers for an online search. IF not then you have to try to use the BLackBerry 7280 LCD as a search string. You may even have to look at a 7280 that is broken other than the screen. Then harvest the screen from that.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 63
