Zum Hauptinhalt wechseln
Apples Nachfolger des Dock Connectors. Dieses Kabel wurde seit 2012–2021 mit den meisten mobilen Apple-Produkten mitgeliefert.
Need help figuring which wires to connect for charging
I am doing an experiment and trying to connect a usb c part of an iPhone charger cable to a usb a part. When I opened the charger that had a USB c, it didn't look like anything I have seen before (has 1 blue, 1 white, 2 copper, 1 green, and 4 uninsulated wires.) the usb a part has the standard (1 white, 1 red, 1 green 3 uninsulated)
which wires do I connect for charging? and which wires do what? (like ground, data -/+ etc) I cannot connect the wires to the port because I do not have to materials to do that.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@gajab
white = Data -
red = +5V
green = Data +
ground is ground.
Take a look at the answers on here USB-C to lightning wiring diagram as well as on here Don't know how to arrange the wires to the USB connector of the cable
Explain to us what you mean by this "I do not have to materials to do that"
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I dont have a new connector, although I do have solder so I will risk trying to solder the part together
i am currently trying to open the usb c part to look at the pins
von
@gajab the pinout should be the same as in the second answer i linked to.
von
Antwort hinzufügen
gajab wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 2,262
