Does anyone know the rating of these capacitors?
I was repairing this switch when I lost one of these four capacitors. Was wondering if anyone can tell me the rating. Thanks in advance
Ist dies eine gute Frage?
Is this motherboard HAC-CPU-01(10), or HAC-CPU-20?
I was able to find some partial schematics for the first option, and they have some parts labelled, so if you have HAC-CPU-01(10), if they include a capacitor that is a match for your missing one it will likely be the same, but if not I can keep looking and maybe find something better.
War diese Antwort hilfreich?
The motherboard says HAD-CPU-10. Thanks!
@jonathancutrona HAD-CPU-10 and HAC-CPU-10 are interchangeable as far as components go, so you're good there. It may be worth measuring the 3 that are still attached to the board. As they look identical it is likely that they will be the same if you can get a good reading off of the other 3 that match.
I can't seem to find any others that identify capacitors on that board.
I found these partials on GBATemp forums and TronixFix forums, respectively, so some users there have at least access to these and likely more. If you need the schematics specifically that may be a good place to ask for them.
Thank you so much for your help!
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 238
