Zum Hauptinhalt wechseln
Kleine Kaffeevollautomaten von Melitta. Diese Anleitungen können auch bei anderen Melitta-Modellen und bei Kaffeevollautomaten von Nivona, Siemens und Miele helfen – die Modelle sind ähnlich aufgebaut.
19 Fragen Alle anzeigen
Selection button not responsive
The single cup serving button is not responsive, but the 2 cup button works ok.
Is this controlled by a micro switch?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
I did not do this repair until now, but I'm quite sure, there is a microswitch, which has to be replaced. Another possibility: replace the PCB. I found a used one for you at ebay.
Use this guide to open the Caffeo and have a look.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
The info was useful for disassembling but there is more work to do to release the front panel. It looks like the fault will be with the pcb/ display/ switch pack.
The link to the pcb/display controller on eBay do not post to the UK.
Thanks.
von
Don't they ship to UK?
Bewertung 2
1 Kommentar:
No they don’t ship to uk.
After looking at the inside of the machine after 2.5 years use, it looks well worn so I have decided to get a new one as I think there will be other problems ahead.
von
2.5 years - that's nothing! These devices live nearly forever, just like airplanes, if worn parts are replaced in time.
Another possibility: the service of Melitta itself is good and not too expensive.
Bewertung 1
Antwort hinzufügen
Steven Mccluskey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 113
