Zum Hauptinhalt wechseln
My Samsung galaxy F12 mobile is not getting charged with own charger
My Samsung Galaxy F12 mobile is not getting charged with its own charger but getting charged with only one another charger
Please help me with this situation
I've used 2 chargers majorly
One is output 5v
Another output 9v
But now the phone's accepting only 5v charger
Not 9v
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
This might indicate that the original charger is broken
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
The phone's charger which came along with mobile isn't broken coz it's charging another things as usual
von
@madmax94338 "charged with only one another charger" means you've tried multiple chargers. You need to let us know what the voltage outputs on those chargers are. In particular, we'd be interested in the voltages for the one that works. Also, there is a possibility that (if you tried other chargers) the USB-C port is having issues. Double check for that as well.
Update (07/18/23)
@madmax94338 this sounds like a daughter board issue. That is your charging board. Something like this one
If that doesn't change anything, follow the Samsung flow chart and measure the components accordingly. The components are the ones the blue arrows are pointing to.
For any abnormality you find while you work on your phone, you can always add pictures to your Question. That way we can see what you see.
Bilder zu einer vorhandenen Frage hinzufügen
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Bewertung 0
3 Kommentare:
One is output 5v
Another output 9v
But phone is accepting only 5V charger now
Please assist me in this situation
The charger which came with phone is 9V
von
So
According to u guys
This is a hardware problem?
von
yes I would definitely look into the charging port
von
Antwort hinzufügen
Madmax wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 483
