Zum Hauptinhalt wechseln
Informationen zu Reparatur und Zerlegung des Samsung Galaxy A22 Android-Smartphones, veröffentlicht im Juli 2021.
My phone is not chrarging in fast charger
My phone is charging only with low voltage chargers or with low voltage supplies powerbanks
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
During the chargar season, there are many hours and they are saying that it is full and it is difficult
von
Charging is very slowly
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @patelparth
Here is an image taken from the service manual for the phone, showing the charging troubleshooting flowchart and also some images showing the components mentioned in the flowchart giving their location (zoomed in and also of the board they're on) in the phone.
(click on images)
It may be as simple as a faulty USB-C connector if it fails the first test i.e. it says to replace the sub pba (charge port board.
There are videos online that show how to either replace the charge port port entirely or to remove the board so that the USB-C port can be replaced. You would need to have smd (surface mount device) soldering skills and tools to just replace the USB-C port, changing the whole charge port board may be easier.
War diese Antwort hilfreich?
Bewertung 2
could be a possible issue with the charging port
Bewertung 1
Antwort hinzufügen
Patel Parth wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 659
