Will a Samsung 1TB SSD, 860 Evo fit in my laptop
Macbook Pro, late 2000 13 - 15 inch.
Will a Samsung SSD 1TB 860 fit OK?
Ist dies eine gute Frage?
@lindavidmartin From this guide, it does not look like that will be possible. You will need a special SSD as these laptops use a proprietary connector that is not M.2 nor 2.5" SATA, such as an OWC Aura which can be purchased here.
War diese Antwort hilfreich?
@lindavidmartin So this model laptop does not use the usual standard M.2 or SATA SSD Connectors, so you will not be able to use most off the shelf SSDs. You will need to buy a special SSD, like an OWC Aura. It looks like your specific model is supported, but do double check with your exact model.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 33
1 Kommentar
Should have been late 2013.
von lindavidmartin
