Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfügt über Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-Anschlüssen)
142 Fragen Alle anzeigen
Keyboard and Trackpad stopped working
Hi! I have a MacBook Air M1 (2020) and after two months of my warranty expiration the keyboard and the trackpad suddenly stopped working. No liquid was spilled and no other damage was made.
The backlit of the keyboard works but the keyboard and the trackpad are both dead. If I connect an external keyboard and mouse they work fine (also if I press the caps lock on the external keyboard the led on the internal keyboard does not lit up).
I tried everything on software level with no luck. I opened the laptop and cleaned all the connectors with isopropyl alcohol but nothing happened. The ribbon cable and the connectors have no visible damage. Also I disconnected the keyboard connector from the board and left only the trackpad part of the ribbon connected with no result.
Is it worth to give $20-$30 try a new ribbon or it may be a motherboard problem? Apple said that the cost of the repair could go up to $600.
Thank you!
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Both the keyboard and trackpad signals travel to the logic board over the one cable assembly MacBook Air 13" (A2179, A2337 2020) Trackpad Cable so it’s worth the expense to replace it first.
But before we do that how does the battery look? Compare it to the images in this guide MacBook Air 13 Zoll Ende 2020 Akku tauschen as a puffed up battery can cause problems with the cable.
Was someone inside before this happened? One other possibility is a damaged logic board connector so when you take the cable off really inspect the contact pins didn’t get damaged on the board side and I would also check the cable end side as well.
MacBook Air 13" (A2179, A2337 2020) Trackpad Cable Bild
Produkt
$14.99
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
The battery is flat like the one in the pictures. I have this laptop from day one and I only opened it, after the problem. I will order the ribbon cable for a start as there is no visible damage on the logic board connector.
Thank you for your reply
von
Antwort hinzufügen
Tasos Ionas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 70
