Why is camera not turn ON
Camera not turning on
Ist dies eine gute Frage?
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide Sony Cyber-shot DSC-S2100 LCD Replacement to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
War diese Antwort hilfreich?
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 43
Insgesamt: 300
4 Kommentare
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
von jayeff
Yes, I already checked it
von Priyeshcamera
Start problem not running
von Binod Saw
Camera is 1year old please recover
von Display is on but don't work
