Zum Hauptinhalt wechseln
Replacing Touch Screen on Life Fitness 95X
My touchscreen broke on my Life Fitness 95X elliptical. I was able to order a replacement on AliExpress, however to install it I need to remove the old one first and reattach it to the bracket.
The old touchscreen component appears to have a strong adhesive to a metal frame. What do you suggest I use to remove the glass and then what should I use to reattach it?
This is the original screen attached to the frame :
This is the replacement touchscreen, which is just the glass panel:
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
@jasongurwin What adhesive removers have you tried? I would start by trying Isopropyl (Rubbing) Alcohol and gently trying to pry the frame out. If that doesn't work, you can use acetone, but be careful.
von
Einen Kommentar hinzufügen
2 Antworten
For first you must deattach metal frame and digitizer ,after that when you connect everything plug the MASHINE.YOU NEED SOFTWARE TO CALIBRATE NEW DIGITIZER.Also stuff from ali express sometime not working .
Dejan Čekanović
Belgrade
Serbia
War diese Antwort hilfreich?
Bewertung 0
Yes is yust a glass panel
Bewertung 0
Antwort hinzufügen
Jason Gurwin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 55
Insgesamt: 385
