In cpc power supplying is not coming
In cpu power supplying is not working
Ist dies eine gute Frage?
@devika14103 checked the power supply by disconencting the power supply from the motherboard. Then place a jumpoer between the green wire and a black ground wire. Since we do not know exactly what power supply plug you have, it will help if you post a picture of it with your Question. We can then show you where to place the jumper. Bilder zu einer vorhandenen Frage hinzufügen
If it does not work, you know you have a bad power supply. If it does work you need to check the power button as well as the motherboard.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 34
