Zum Hauptinhalt wechseln
2,3GHz, 2,6GHz oder 2,7GHz Quadcore Intel Core i7 Prozessor (Turbo Boost bis zu 3,7GHz) mit 6MB geteiltem L3 Cache.
Right Speaker issues after battery was replaced.
After I replaced my MacBook Pro 2012 Retina Battery today with iFixit, my right speaker is now crackling. The only thing I changed was the battery and no other cables or board was touched.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Sorry to hear that😔
Sometimes other things break in the process or just the movement of your actions sets things off. Time to replace the speaker MacBook Pro 15" Retina (Mid 2012-Mid 2015) Right Speaker
Replace a used right speaker compatible with the Mid 2012 to Mid 2015 MacBook Pro 15" Retina laptop. Fix issues with sound output. Part #923-0660, 076-1401, 609-0319, 609-00012. Bild
Produkt
$29.99
War diese Antwort hilfreich?
Bewertung 0
This seems to be a misalignment issue of the new battery (a common fault) or when removing the old battery accidentally denting the fragile speaker cones causing the rattle. These Retina 2012 macs had terrible speakers to begin with anyway. If the distortion occurs even at low volume it's almost certainly a torn cone.
Or on a more positive note maybe it's a loose speaker screw that needs tightening.
Bewertung 0
Antwort hinzufügen
Thomas Doiron wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 184
