Zum Hauptinhalt wechseln
Alle Schraubendreher, die von iFixit hergestellt und auf iFixit.com verkauft werden.
Is there ball end hex for iFixit screwdriver? I can only see straight
Hi, is there ball end hex for iFixit screwdriver ?
I have iFixit 64 bits, and I can only see straight. I need a ball end to reach screw by an angle. Where can I buy these bits for iFixit screwdriver ?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @chris44982
Looks like ifixit doesn't have ball end hex bits but perhaps you could use something like these (examples only) in conjunction with the 1/4" to 4 mm Driver Adapter in the kit.
Update (09/01/23)
Hi @chris44982
Here's an image taken from the ifixit Mako Driver Kit - 64 Precision Bits tool kit which I assume is the one you're referring to, showing the location of the 1/4" → 4mm driver adapter in the kit.
It's a bit hard to see but under each bit is an embossed description of what the bit is. You can see them more clearly in the zoomed in image I posted below. Why they didn't have the description in a different colour e.g. white, I don't know.
Also in the link for the toolkit I posted on the right side of the page is a link that shows the kit contents.
(click on image above)
iFixit's 4 mm aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top — plus 64 essential precision bits to tackle sneaky security screws. Bild
Produkt
$39.95
War diese Antwort hilfreich?
Bewertung 3
Where the 1/4" to 4 mm driver adapter in the kit ?
Are we talking about the same kit ? This is my iFixit 64bit kit :
Bewertung 0
2 Kommentare:
Hi, I have got no reply, where the 1/4" to 4 mm driver adapter in the kit ?
von
@chris44982
I replied 5 days ago in my answer above - see the update 09/01/23
von
Antwort hinzufügen
Chris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 29
Insgesamt: 541
