Zum Hauptinhalt wechseln
Die Apple Smartwatch der 7. Generation mit optionaler Mobilfunkverbindung, herausgekommen am 15. Oktober 2021.
Will a 42mm battery fit in a 38mm Apple Watch?
I have a 38mm series 7 Apple Watch and recently the battery went bad and I need to get a replacement. I was looking for a replacement battery for the 38mm Watch but I can only find them for the 42mm and 45mm. so are the 42mm battery’s interchangeable with the 38mm watches?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Simple answer no!
You can’t physically fit the larger battery into your watch.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Just to expand on Dan's absolutely correct answer, devices like cell phones and watches custom design their batteries to fill all available space to give you the maximum battery life. So naturally since the 42mm watch is bigger than the 38mm watch, that means there's more space inside to hold a battery. Which means the battery is going to be bigger and, as Dan pointed out, you can't fit the larger size battery into the smaller space.
von
If I can’t fit the 42 mm battery in the Watch do you guys have any idea where I might be able to get a 38mm one?
von
@eliduffer - Here’s the guide and it offers the needed parts to replace the battery Apple Watch Series 7 Akku tauschen
von
Antwort hinzufügen
Eli Duffer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 480
