Zum Hauptinhalt wechseln
The K-Mini is a compact and functional coffeemaker manufactured by Keurig.
water reservoir supply line has pin hole
K-mini is leaking water i found pin hole in the supply line from the reservoir the easiest repair would be to cut it and use a coupling but I'm clueless as to it size or if replacement would be a better but not easier option
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Two things I would recommend are to take the hose off and take it to a hardware store to see which tubing would fit as a replacement or get the tubing off of eBay. Here's a link to some replacement hoses: https://www.ebay.com/itm/304995886425?mk...
Hope this helped!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
techranger59 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 33
Insgesamt: 273
