How to Realign Gears on my Saeco Vienna Plus?
My gears are misaligned on my Saeco Vienna Plus and I can not get the brew unit to snap back in to place. How do I realign?
Ist dies eine gute Frage?
So try, If the motor works, use the test mode as explained here:
https://youtu.be/Ng-zQurYhXA?si=lDLFR-2k...
and here:
https://mschausprojects.blogspot.com/202...
Using the test mode the gears can be turned to the correct position. If not, a gear might be broken and you have to open the gear drive.
War diese Antwort hilfreich?
Thank you so much! That did fix it!
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 41
Insgesamt: 187
1 Kommentar
@vauweh what do you think about this? any chance you could help @kimmhammar out on this one? ;-)
von oldturkey03
