Zum Hauptinhalt wechseln
Reparaturanleitungen für Computer, die über kein integriertes Display verfügen und für den stationären Gebrauch gedacht sind.
2134 Fragen Alle anzeigen
(System crashing)Computer gets power, but monitor says no signal
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000007f (0x00000000, 0x00000000, 0x00000000, 0x00000000). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 022512-20342-01.
plz help me
windows 7 32bit
dh61ww =core i5 2320
500gb hdd seagate
4gb transcend single stick
HD6750 ddr5 1Gb
zeb-450w gold series
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The 0x0000007f, UNEXPECTED_KERNEL_MODE_TRAP, error code means a trap occurred in kernel mode and the trap is either one the kernel is not allowed to have or is always fatal. That trap is defined with the first parameter 0x00000000 as being a DIV instruction is executed and the divisor is 0.
The most likely causes of this error are overclocking something on the board (CPU, RAM, video or a bus) or low-level hardware corruption, such as corrupted/bad RAM or RAM slot - RAM includes video RAM.
Try reseating your RAM and video card. If that doesn't help try your RAM in another slot. If that doesn't help try different RAM. If that doesn't help try a different video card or try the video card in a different machine. If you are overclocking something, bring the system back to normal pace. If you have put RAM in the system that is in anyway different (faster, larger, timings, etc..) than what the motherboard manufacturer says is compatible with the system or the slot change the RAM following their requirements.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
karty wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 856
