Hey guys! Sometimes the smack will work, since a hard jolt is most likely what caused the issue in the first place. If that doesn't work, you'll need to open up the iPad and gain access to the LCD cable. Most likely that cable is loose and needs to be reinserted into the ZIF connector.
Then if that doesn't solve your problem you will need a new LCD. I can't really give you exact links to help you with the repair until I know what model of iPad you have. There is a number on the back that starts with A and then has 4 digits after that. It should say either A1395, A1396 or A1397 if it is an iPad 2.
You can find out what model you have on this page on Apple's website.
Just let me know what model iPad you have (iPad 2, iPad 3, etc.) and I'll help you figure it out.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
20
hi my touch panel is broke but screen is warking I am change the screen but after I fix all part screen not come on but sound is coming whate I can do pleas
von roofi
try to tap it with your hand on its back frequently and then press power button
von haris
I cannot believe it.... It works! I too had nothing to loose after my daughter dropped her ipad and the screen was black. A couple hard smacks on the back and the screen came back on. Thank you thank you thank you!
von Deb
Thank you! My daughter's iPad does this all the time and I keep forgetting how I fixed it last time LOL
von andersonbecca
Thank you so Much!!!!!!!!!!!!!it worked same scenario as above thank you...
von CHETAN SINGH
79 weitere Kommentare anzeigen
