Zum Hauptinhalt wechseln
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
20 Fragen Alle anzeigen
intermittent f6 code flashing on display.
Hello,
I get a f06 code on the washer when I run a complete wash cycle. I can usually run a rinse and drain cycle. I read the f06 post and tried unplugging and replugging various connectors on the CCU and MCU. I suspect a failing part, possibly a speed or rotation sensor. Where are these sensors?
Ist dies eine gute Frage?
Bewertung 0
9 Kommentare:
Hi @mron,
What is the model number of the washer?
von
It's an elite quiet pack 4
von
@mron
The model number would help to ensure that if parts are required that the correct part can be found.
von
110 45972400
von
110 45972400
von
4 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Diese Antwort bezog sich ursprünglich auf eine andere Frage.
Hi @mron
There is no balance sensor in the washer. At least there's none shown in the parts list for the washer.
Intermittent problems can be hard to find so perhaps try checking the connections between the MCU and the drive motor to see if they're all OK i.e. not loose, corroded etc.
Here's the tech sheet for the washer that may also help. On p.8 it describes how to check the windings for the motor, just in case one winding is not within spec or is on the limit of what may be acceptable to the MCU.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
The tech sheet is very helpful! thanks
von
Antwort hinzufügen
Ron Moreland wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 96
