Zum Hauptinhalt wechseln
Reparaturanleitung und Informationen zur Fehlerdiagnose für die kabellose Apple-Maus mit Multi-Touch-Unterstützung. Modellnummer A1657 oder A3204.
Magic Mouse 2 in not connected
When I switch on the Magic Mouse 2... on screen says "Mouse Connected". Few seconds later, on the screen says:" Connection Lost" I'm thinking about the battery of the mouse( 2 years now, non stop working). But the battery is a common on. Thank you in advance for your help. Panagiotis Badalakis
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
While its possible the battery has failed, I would first give the mouse a good over night charge (better than 8 hours) use your iPhone charger as your system likely won't let your mouse charge when in sleep mode.
In any case heres the guide and the battery info Magic Mouse 2 Akku tauschen
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
thank you very much, dear dan. i saw that the battery costs about 85$, and the new one round 100$. does it worth it?
von
@panagiotis81413 - For some people that $20 does. For me it’s the principal of throwing away a still functional device when it only needed a battery. We’ve become too throw away wasting resources.
But, before you make that jump make sure the battery is truly bad. Often times it’s just not getting a good charge.
von
Antwort hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 427
