Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für LG Smart TV. Hier findest du alles, was du für deine LG Smart TV Reparatur brauchst.
20 Fragen Alle anzeigen
TV sparked, popped and now won’t work.
We have taken the back off and can see no obvious damage to the main board however there is a black mark on the casing, what could be the cause? Thanks in advance
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
See images - no damage to main board just a mark to the casing
von
@rachelbrookes there are no images showing
von
@rachelbrookes The images didn't upload. Please try again. Bilder zu einer vorhandenen Frage hinzufügen
von
Einen Kommentar hinzufügen
3 Antworten
Arcing and popping are not good noises. The main board in a TV is pretty complex so you may not be able to see the area where the sparking occurred without careful scrutiny. Can you smell that smell, the smell of electronic sparking? (a tip of the hat to Lynyrd Skynyrd )
With the price of TV's so reasonable, I'd recommend just tossing what you have and buying new.
War diese Antwort hilfreich?
Bewertung 0
Sounds like it could be an electrical issue. For safety, unplug until damage can be repaired.
Bewertung 0
@rachelbrookes first off, do not just toss what you have! We need to stop the insanity of wasting valuable resource by discarding products that are repairable. Repair will keep our hard-earned money in our pockets instead of further feeding the Profit-before-People (Planet) machinery.
The very first thing we need to know is the exact make and model for your TV. then unplug it (if you have not already done this) and remove the back cover. Now take a couple of really good , clear, large enough pictures of every circuit board you can see. Post those with your QUESTION. That will allow us to see what you see. Include the area with the black mark
Going by your description alone, this sounds very much like a blown component. From the noise you heard to the black mark on the case, it is most likely a MOSFET. Again, let's see what you got going on here.
Use this guide Bilder zu einer vorhandenen Frage hinzufügen to add the images.
Repair is War on Entropy!
Bewertung 0
Antwort hinzufügen
Rachel Brookes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 138
