Zum Hauptinhalt wechseln
Apples neues Format der 14er Reihe verfügt über ein 6,7" OLED-Display - wie das Pro Max - ansonsten aber über die gleichen Funktionen wie das iPhone 14 mit einem Zwei‑Kamera-System und dem Bionic A15 Chip mit einer 5-Kern-GPU.
Extra part after disassembly, please help!
Hi guys,
I've taken apart my Iphone 14 Plus to put everything in a new housing. unfortunately in the process I've taken something out which I now don't know where belongs. Can anybody please help?
Thanks a lot!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Thanks for the input @flannelist. Some very close inspection of teardowns helped me to find the location. It's something between the speaker and the charging port part. I've attached a picture below. Phone all working now! Thanks!
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
I have not worked on one of these yet. But Apple loves little bits like these. It looks like an antenna of some kind. Based on the way its shape I would wager it goes into the side of the housing somewhere, like a button flex. My first through would be the NFC antenna which is usually in the sidewall of the housing near the rear camera. But I haven’t been able to pin down the location for sure.
Here’s a pretty in depth teardown for the 14 Plus on a top down view. You might be able to find the placement based on this.
https://youtu.be/QlkC6_AiinU?si=9s53xDZB...
Bewertung 2
Antwort hinzufügen
Michael Buijs wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 23
Insgesamt: 432
