Zum Hauptinhalt wechseln
A1418 / EMC 2833 / Ende 2015 / 3,1 GHz Core i5 oder 3,3GHz Core i7 Prozessor. Erscheinungsdatum 13. Oktober 2015.
My iMac is a A1418 / EMC 2883, iFixit only has A1418 / EMC 2833, same?
Hello, I have an "iMac Core i5 3.1 21.5" (4K, Late 2015)" My iMac is a model "A1418 / EMC 2883", yet when I put my serial number into everymac, it returns a model with the exact same specs and model, yet the EMC number is 2833 rather than 2883. Similarly, iFixit only has guides for A1418 / EMC 2833. I would like to replace the HDD in this mac with a 2.5" SSD, and I have found the following iFixit page with a drive replacement guide: iMac Intel 21.5" Retina 4K Display 2015 as well as these adhesive strips: iMac Intel 21,5" Display-Klebestreifen tauschen
I have a feeling that my EMC number is slightly different due to the fact that this iMac has 16GB of memory instead of the standard 8GB of memory? Anyway, my question is: can I safely follow the guide above and will the adhesive strips work for my iMac?
Many thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Looked up the serial number on:
  • checkcoverage.apple.com
  • macfinder.co.uk
  • appleserialnumberinfo.com
All the sites seem to report it as iMac (Retina 4K, 21.5-inch, Late 2015) with 8GB RAM, so the different EMC number is probably due to the increased RAM. Anyway case/instructions/adhesives should be the same
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
GoopGoop wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 1,477
