Zum Hauptinhalt wechseln
Informationen zur Reparatur und Demontage für Samsungs S20+ Android Flaggschiff-Smartphone vom März 2020
Front screen replacement kit
The front screen of the phone is cracked and the touch screen doesn't work, do you have a product to replace that and make the touch screen start working again?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@prithvirajpatel for your phone the touch screen, the glass and the LCD are all "sandwiched" together to make this the display assembly. In your case, it is best to replace the complete Display assembly.
Look in the note of this guide Samsung Galaxy S20 Plus Display tauschen You'll find that "Some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires you to transplant all of your phone's internals and install a new battery. Make sure you have the correct part before starting this guide.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure."
It would be best to replace it with something like this Samsung Galaxy S20+ (USA) Screen and Battery - Genuine
Your phone uses an OLED screen and those are not cheap.
Replace a screen and battery assembly for a Samsung Galaxy S20+ smartphone for the US market. Fix issues like a scratched screen, touch issues, or a dead battery. 6.7 Inch 3200 x 1440 pixel AMOLED Display. Bild
Produkt
$216.99
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
prithviraj patel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 651
