Zum Hauptinhalt wechseln
Repair guides for Dell Inspiron laptops. A line of mid-level Dell laptop computers.
1401 Fragen Alle anzeigen
I cant get my Dell Inspiron 1564 to load windows 7
When i turn my laptop on it goes right to windows error recovery . it says windows failed to start. A recent hardware or software change might be the cause. to fix the problem:
1. Insert your windows installation disc and restart your computer.
2.Choose your language settings, then click next.
3. click repair your computer.
I dont have the disk its talking about. Is there any way around that?
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Deanne Richardson, check this current question Fresh install of windows 7 from another machine? and look though the answers. Try to access your recovery partition. When the system boots, immediately press the Ctrl and F11 keys at the same time and you will enter the Dell Recovery Restore Utility.There is also the possibility it might work when you hold down the number 0 key or the F5 on startup. See if you can recovery from there. Also check on the links for further information. Let us know what you get.
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Download the correct ISO file from:
http://forum.notebookreview.com/windows-...
Burn it to a DVD. Boot your laptop from the DVD. Follow the instructions you've already posted.
War diese Antwort hilfreich?
Bewertung 2
Have you tried to start the laptop in safe mode? After you press the power button start and continue to press F8 until you get the options for start up. You will have safe mode last known good configuration that worked.
I would try safe mode first and see if it will boot into that. If it will not boot into safe or the last known good config does not work you can always use the Dell system restore to restore back to a working state.
Bewertung 1
1 Kommentar:
Yes I have tried all the abve that you have mentioned and it wont budge.
von
fresh installation of new windowshave once same problemi have to install new windows,,
Bewertung 0
I am going to try now and download the correct ISO file from this link as you suggested.
Bewertung 0
Antwort hinzufügen
Deanne Richardson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,422
