Zum Hauptinhalt wechseln
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
20 Fragen Alle anzeigen
Quasar VCR isn’t working
When the VHS tape is in the VCR there’s a spinning sound/catching noise, and it doesn’t play the tape. It doesn’t rewind or forward either but ejecting the tape is fine.
Update (12/29/23)
This is the info on the back of the VCR.
Thank you!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @eph23
Check if the drive belts are OK and not stretched or broken.
I can't find replacement belts for the VCR model online so if they are broken etc unless there's a part number on the belt itself (unlikely) you may have to purchase the service manual and check if there's a parts list in that, where the belt part number is shown so that you can search for it.
If the belts are OK then the service manual should help to find out what's wrong.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
@jayeff Thank you so much!! I will look into that and thanks for the link to the manual. I really appreciate it!
von
Antwort hinzufügen
eph23 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 139
