Zum Hauptinhalt wechseln
Informationen zur Reparatur, Demontage und Fehlerbehebung für das iPhone 15 Pro Max, Apples Flaggschiff-Smartphone der Spitzenklasse, das am 22. September 2023 veröffentlicht wurde. Es verfügt über ein 6,7 Zoll ProMotion OLED-Display, ein Rückkamerasystem mit drei Linsen und einem neuen 5-fach optischen Zoom sowie 5G. Nachfolger des iPhone 14 Pro Max.
20 Fragen Alle anzeigen
New iPhone Max Speaker Max Volume
I noticed that the iPhone 15 seems to ship with a phone call loudspeaker sound set at max. I've had two now, and when making a first call on each and putting on speaker, it was per set at max loud volume.
It was a little annoying, but it led me to wonder if a call or music at max volume would harm the speakers. I can only assume that Apple has thought of that and made sure it operates within safe limits, but the internet seems to think you can damage them. Wondering what you folks think?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Modern smartphones are designed with speakers that can handle a wide range of audio volumes without sustaining damage. Manufacturers typically ensure that the maximum volume level is within the safe operational limits of the speakers. This means that even at the highest volume, the speakers should not be damaged under normal conditions.
However, while occasional use at maximum volume is unlikely to damage the speakers, consistently playing audio at such high levels can potentially shorten the lifespan of the speakers. This is due to the increased wear and tear on the speaker components when they are consistently pushed to their limits. At max volume, you may experience a decrease in audio quality, characterized by distortion or a muffled sound. This is not necessarily indicative of damage but rather the speaker struggling to reproduce sound clearly at high volumes.
Apple may also include software limitations to prevent the speakers from reaching a volume that would cause damage.
TL;DR Speaker shouldn't be damaged unless consistently playing audio at max volume, but even then it is likely that Apple has implemented some software that would limit the potential for any issues.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
J T wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 135
