Laptop went off and can't switch it on. the board is getting hot
Ist dies eine gute Frage?
@keithmazyopa start disassembling your laptop and let's see what you got going on here. Use something like this video to work on it. Once you have it disassembled, take some good pictures of the board. Then post those with your Question. It will allow us to see what you see. Also, verify that it is the board that gets hot and not the battery. Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
A hot board is a sign of high current draw. You need to ID the hot part. It could be part of the CPU power supply. That might indicate a bad CPU. If the CPU is hot, that would also indicate a bad CPU. OR the CPU PSU is putting out to much voltag to the CPU.
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 28
Insgesamt: 667
6 Kommentare
Hi, Do your fans come on when you try to power on the laptop?
von James
thank you , but this one it has no fans
von Keith Mazyopa
I'd like to know if there was water damage done to the laptop, if not i think you should try booting it into recovery mode
von CheckM@te
@keithmazyopa Is it a Chromebook?
von James
लैपटॉप ऑन नहीं हो रहा है
von ajeet kimar
1 weiteren Kommentar anzeigen
