Zum Hauptinhalt wechseln
The TI-83 Plus is a graphing calculator released in 1999 as an upgrade to the TI-83.
How do you make the screen stay dark by default?
My screen is dark by default, I was trained to reset my calculator after each equation or session. When I do this, my screen's contrast turns faint and I have to adjust. Is there a way I can make it stay dark without having to reconfigure?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The purpose of the reset is to set everything to the factory default settings so you'll have to adjust your habit.
Instead of resetting the calculator, you can press 2nd then + then scroll down to Clear Entries and press enter twice. Your previous calculations will be wiped but no settings will be changed.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Nephtali Valdez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 136
