Zum Hauptinhalt wechseln
Die zehnte Generation von Samsungs Flaggschiff-Phablet mit seinem S-Pen als Kennzeichen. Erschienen im August 2019.
Induktives laden funktioniert nicht
Das induktives laden Teil vom mein Handy funktioniert nicht ich hab es zwei Mall getauscht und es funktioniert immer noch nicht, hab 3 verschiedene induktiv Ladegeräte und es funktioniert immer noch nicht ich denke nicht das ich etwas beschädigt hatte weil Emin NFC Antenne funktioniert normal.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@dimitris612 I am making the assumption, that since you already replaced the wireless charger, that you also made sure that this is not anything software related. At least a restore, if not a total hard reset, might be a good idea as well. Of course, you will have to back up all of your files etc. since you will lose those. You also need your Google account/password etc. that you've used to set-up your phone.
I would definitely change the antenna as well. Yes, it might be unlikely that it is damaged but remember, nothing is impossible. It is not good to just going by the assumption that it works. I strongly suggest that you replace it as well.
After all of that and if it still does not work, I would suggest that you follow the short Samsung flowchart and check those components. The diagrams may look different since we are not sure exactly which version your phablet is and there are a few different ones. See if these match.
If we need to get even further to a boardlevel check, we can do that too. However, start with the antenna and work your way up teh ladder. Let's start with the easy stuff and then the tougher stuff.
You can also post some images of your boards. that way we can see what you see. https://de.ifixit.com/Anleitung/Bilder+z...
Translation
@dimitris612 Ich gehe davon aus, dass du, da du das kabellose Ladegerät bereits ausgetauscht hast, auch sichergestellt hast, dass das Problem nicht softwarebedingt ist. Zumindest eine Wiederherstellung, wenn nicht sogar ein kompletter Hard-Reset, könnte ebenfalls eine gute Idee sein. Natürlich musst du alle deine Dateien usw. sichern, da du sie verlieren wirst. Außerdem brauchst du dein Google-Konto/Passwort usw., das du für die Einrichtung deines Telefons verwendet hast.
Ich würde auf jeden Fall auch die Antenne austauschen. Ja, es ist zwar unwahrscheinlich, dass sie beschädigt ist, aber nichts ist unmöglich. Es ist nicht gut, einfach davon auszugehen, dass sie funktioniert. Ich empfehle deshalb dringend, auch die Antenne auszutauschen.
Wenn es nach all dem immer noch nicht funktioniert, würde ich vorschlagen, dass du dem kurzen Samsung-Flussdiagramm folgst und diese Komponenten überprüfst. Die Diagramme können unterschiedlich aussehen, da wir nicht genau wissen, um welche Version es sich bei deinem Phablet handelt und es einige verschiedene gibt. Schau nach, ob diese übereinstimmen.
Wenn wir noch weiter gehen müssen, können wir auch eine Prüfung auf der Platine durchführen. Fang jedoch mit der Antenne an und arbeite dich die Leiter hinauf. Beginne mit den einfachen Dingen und dann mit den schwierigeren Dingen.
Du kannst auch ein paar Bilder von deinen Boards posten. Auf diese Weise können wir sehen, was du siehst. https://de.ifixit.com/Anleitung/Bilder+z...
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Dimitris_612 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 276
