Zum Hauptinhalt wechseln
Informationen zur Reparatur und Demontage der tragbaren kabellosen Logitech MX Anywhere 3 Maus. Veröffentlicht im Jahr 2020 und gekennzeichnet durch die Modellnummer 910-005986, 910-005833, 910-005987 oder 910-005985.
phantom clicking in Anywhere MX 3
Same problem addressed for Anywhere MX mouse, but since this model is different, I wonder if there's another solution.
This happened after around 1.5 years of use.
My partner has the same mouse and the same problem, using a different OS, so it seems to me to be a hardware problem.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
4 Kommentare
Hi @glicerico
What had you tried? had you tried replacing the micro switch?
von
No, I don't know what the micro switch is or how to replace it. Is there a guide? If you are referring to the article I linked, I planned to do it, but saw in the comments that some people tried with the Anywhere MX 3 and didn't work for them
von
Ah, I think the micro switch is the module containing the clickable part. No, I didn't replace that, I don't have the spare part.
von
After I reassembled my MX Anywhere 3 mouse, when I turn on the switch, the LED at the back of the mouse wheel only blinks red. I have already tried charging it, but the red LED keeps blinking whether it is charging (with the power switch turned on or off) or not charging (with the power switch turned on). Additionally, the LED on the Bluetooth switch, which has 3 options to connect up to 3 devices, no longer turns on. Does anyone can help me?
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Inspired in the guide for the Anywhere MX mouse, I opened the Anywhere MX 3, and although it's not built the same way, the solution was simple.
After carefully removing the 4 pads in the bottom of the mouse, then the 4 screws below them, I opened the mouse and saw the white elongated button responsible for the click.
I cut 3 small squares of black electrical tape
to fit the contact point with the click button on the other side, on the top of the mouse. I pasted the 3 squares one on top of the other in the place indicated by the screwdriver:
then just reassembled the mouse cover, screws, and pads.
This fixed the problem and now my mouse works as good as new :)
War diese Antwort hilfreich?
Bewertung 0
Yep. Same double click issue as all other Anywhere MX, appeared after 2 years of use after mandatory warranty ran out. Starting to believe this is deliberate design flaw. Has happened in 5/5 Anywhere MX mouses I have used.
Bewertung 0
2 Kommentare:
sad situation
von
von
This is a problem, why this sites never advise people to replace the microswitch. Replace microswitch for left and right click and your mouse is like new again
Replace microswitch left click
Bewertung 0
2 Kommentare:
where do you get the microswitch replacements?
von
where do you get the microswitch replacements? i don't know where to look for it because I even know its name
von
Bewertung 0
Antwort hinzufügen
glicerico wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 25
Letzte 30 Tage: 99
Insgesamt: 2,839
