Zum Hauptinhalt wechseln
13" Aluminium Unibody, 2,0 oder 2,4 GHz Core 2 Duo Prozessor.
“5” Key is not working.
Hey guys!
So, the 5 key on my Mac randomly stopped working. I know this key is probably not as significant as the space bar, for example, but I still would like to fix it.
Here’s what I know: the key does nothing when I press it, and it will randomly type the 5 on its own. For example if I turn on Spotlight, it will type 5 many, many times on its own. Yet, when I hit the 5 key on the keyboard, it does nothing.
I have tried the basic steps, like reseating the ribbon cable, resetting NVRAM and SMC, rebooting the Mac and so on. Do you have any suggestions before I simply replace the keyboard?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @jadonlyon
Sounds like the ribbon cable, or connector is bad.
I can say for sure. it is not fun when that happens.
I sent mine to rossmann repair group to be inspected, They replaced the connector.
I find it likely you have the same issue.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
@beanman56 - Unfortunately I am not in a position to send my Mac in for repair, but now I have better idea on where to check. Thanks for the help!
von
@jadonlyon - I would have a good repair shop test with a new keyboard.
So you're not out $20 if it's something else.
von
@beanman56 - Sounds good, thanks!
von
Antwort hinzufügen
Jadon Lyon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 199
