Zum Hauptinhalt wechseln
Dies ist eine 2011 von Canon entwickelte Kompaktkamera.
Fixes for "Wrong Flash Position, Restart the camera"
I keep getting this error and It would be too expensive to send to canon. What might be malfunctioning here?
P.S. I opened the camera and cleaned it's gears on the flash and it doesn't still seem to work
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@zhyctnani seems to be a common issue with this camera try this "I managed to fix it myself by first turning off the camera and fully pushing the flash all the way down. That did not yet solve the problem. Then I did a reset as described earlier in this thread. Again, no change. Finally, I used a fingernail to pull the flash mechanism all the way up, again while the camera was off. I then turned the camera on and turned it off again, and it retracted. Now it extends and retracts as expected, and with no more errors." from here while we keep looking for a viable solution.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
I felt the need to register just so I could upvote this and say thank you! This fixed the "Wrong flash position" error for me! This was on an S110 rather than an S100 so this fixes at least two models
von
Antwort hinzufügen
Zhyct Nani wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 29
Letzte 30 Tage: 86
Insgesamt: 3,357
