Zum Hauptinhalt wechseln
Repair your Dyson V6 Cord-free vacuum with a part replacement guide.
Unit shuts off after running for 15-20 seconds.
Unit runs for 15-30 seconds then shuts off and will not run again for some time. Tried filter change. Overheat issue?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Battery replacement resolved the issue.
von
Einen Kommentar hinzufügen
1 Antwort
Power issues can be hard to pin down. Although they are usually the result of the battery or connections degrading over time, it could be much simpler, and be caused by overheating.
You could start by removing the battery and wiping the connections over. It’s possible there’s a power consumption issue, with there just not being enough residual charge to run the machine. A new battery should fix this.
Dyson V6 Battery
My other thought is that it’s overheating. If too much power is pushed through the motor, which MAX power does, it could stop after a few seconds if it becomes hot. Rule this out by giving the machine an overhaul. Wiping down the individual parts, cleaning the filter, etc.
Replace the 2500 mAh battery compatible with these Dyson cordless vacuum cleaner models: V6, DC58, DC59, DC61, DC62, DC72, and DC74. Bild
Produkt
Dyson V6 Battery
$68.99
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Kevin Pope wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 321
